[VENDO] Amplificador Integrado Audiolab 8300a
por mati_drum » 27 Ago 2017, 20:26
Estimados, Buenas noches
Vendo Amplificador integrado Audiolab 8300a, Nuevo en caja, para entrega inmediata.
Color Negro , 220V
Precio para el foro $ 28.000 ( se puede pagar con mercado pago al mismo valor)
Especificaciones;
General description Integrated Amplifier
Design philosophy and core technology Dual Mono Power Amp Design
Display OLED 128x64 pixels 2.7"
Controls Logarithmic Ladder Volume Design
Finish Fine Textured Aluminium (Black / Silver)
Standby Features Yes
12V Trigger Yes
Phono Yes (MM/MC)
Balanced XLR Input Yes
Pre-amplifier Section
Inputs CD, Video, Tuner, Aux 1, Aux 2, XLR (Balanced) & Phono
Outputs 2 x RCA
Input sensitivity (Phono RIAA) 50K // 100pF
Input impedance (line inputs) 50K // 100pF
Input impedance (phono inputs) 47K // 100pF (MM), 100R // 1.5nF (MC)
Output voltage 2.3V max. (< 0.02% THD)
Output impedance 120 ohm
Frequency response (Line) +/- 0.1dB (10Hz - 20kHz)
+/- 3.0dB (1Hz - 100kHz)
Frequency response (Phono RIAA) +/- 1.0dB (20Hz - 20kHz)
Channel Imbalance < 0.2dB (10Hz - 20kHz)
Total harmonic distortion (THD) Line <0.001%
Total harmonic distortion (THD) Phono <0.002%
Signal-to-noise ratio (Line) > 107dB
109dB(A-weighted)
Signal-to-noise ratio Phono (MM) > 73dB
78dB(A-weighted)
Signal-to-noise ratio Phono (MC) > 68dB
73dB(A-weighted)
Crosstalk < 80dB (L-> R & R->L @10KHz)
Power amplifier Section
Gain 29dB (20Hz-20KHz)
Input Sensitivity 840mV (Power Out = 70W into 8ohm)
Input impedance 15K // 100pF
Rated max power output THD < 1% 2 x 75W RMS (8 ohm) , 2 x 115W (4 ohm)
(Vmains = 230V , THD < 1%)
Peak output current +/- 15A
Frequency response +/- 0.1dB (10Hz – 20KHz)
+/- 3.0dB (1Hz – 100KHz)
Channel Imbalance < 0.2dB (10Hz – 20kHz)
Total harmonic distortion (THD) <0.002% (Power Out= 50W @ 1KHz, BW = 20Hz – 20kHz)
Signal-to-noise ratio > 107dB (BW = 20 – 20KHz )
109dB(A-weighted BW = 20 – 20KHz)
Damping factor >100 (8ohm Load @ 1kHz)
Inputs 1 x RCA
Outputs Speaker Binding Post Terminals
Dimensions 80 x 444 x 330.3mm
Net weight 7.8kg
Mas Info;
http://www.audiolab.co.uk/product.php?cid=3
Cualquier inquietud no duden en consultar.
Gracias y Slds!
Vincent SV-234 // Oppo BDP-95 // Paradigm Signature S2. V2 // Sansui Sr-737 // Pioneer N-30
mati_drum
por Nico » 27 Ago 2017, 22:06
Belleza
Nico
por gabo » 27 Ago 2017, 22:16
Muy bueno Mati! Exitos con la venta
gabo
por Fadragani » 27 Ago 2017, 22:28
Noooo Matias estas loco !! ja, yo lo tengo y es increible como anda el bicho ese.
No parece ni ahi de 75WATTS.
Bueno , exitos en la venta !!
Fadragani
por leepancho » 27 Ago 2017, 22:41
que lindo equipo. no sabia que contabas con esa maquina. muy completo las entradas etc. control !
leepancho
por enano500 » 28 Ago 2017, 12:42
Muy muy muy lindo ampli maty
enano500
por mati_drum » 28 Ago 2017, 15:41
Muchas gracias a todos por los comentarios. Es un ampli muy completo y lo importante es que suena muy bien.
Tiene muy buenas features.
Se puede configurar para usar de PRE/ POWER o INTEGRADO.
Subo una foto del remoto ya que ni habia subido.
Cualquier inquietud me consultan.
Slds
mati_drum
por soniq » 28 Ago 2017, 22:35
Muy buen amplificador y poco común por estos lares.
Lindo bicho.
por mati_drum » 09 Sep 2017, 15:49
Gracias Sergio!
Siguen en venta!!
Color Negro , 220V
Especificaciones;
12V Trigger Yes
Phono Yes (MM/MC)
Outputs 2 x RCA
109dB(A-weighted)
78dB(A-weighted)
73dB(A-weighted)
Inputs 1 x RCA
Net weight 7.8kg
Mas Info;
Gracias y Slds!
mati_drum
por mati_drum » 24 Sep 2017, 12:41
Estimados , Buenas
Mejoro el precio a $ 26.000 por un tiempo para el foro , esta casi al mismo valor que en Europa.
El que este interesado en escucharlo puede coordinar conmigo o con Fer ( enano500) ya que lo tiene en su showroom :-) :-)
Cualquier inquietad no duden en consultarme.
Gracias y Slds!!
mati_drum
  • Usuarios navegando por este Foro: Google [Bot] y 1 invitado
