Parasound New Classic
1 mensaje
- Christian Enjoy
Set Parasound Pre 2100 y potencia Stereo 2125
Pre 2100
Audio Specifications
Frequency Response
10 Hz - 100 kHz, +/- 3 dB
THD Distortion
< 0.008% at 20 Hz
S/N Ratio
> 105 dB, input shorted, IHF A-weighted
> 95 dB, input shorted, unweighted
Crosstalk
> 75 dB at 20 kHz
Input Impedance
30 k Ω
Output Impedance
< 60 Ω
Input Sensitivity
250 mV for 1 V output
Total Gain: 12 db
Maximum Output: 6.5 V
AC Power Requirement
110-250 V, 50 - 60 Hz
Voltage is automatically selected
5 watts standby; 10 watts when turned on
General Information
Dimensions
Width: 17.25" (437 mm)
Depth: 14.5" (369 mm)
Height, with feet: 4.25" (108 mm)
Height, without feet: 3.5" (89 mm)
Weight: Net: 13 lbs. (5.9 kg)
Shipping: 20 lbs. (9.1 kg)
Power Stereo 2125
Continuous RMS Power Output
20 Hz - 20 kHz, Both Channels Driven
125 watts x 2, 8 Ω
200 watts x 2, 4 Ω
200 watts x 2, 2 Ω
20 Hz - 20 kHz, Bridged Mono
400 watts, 8 Ω
400 watts, 4 Ω
Current Capacity
35 amps peak per channel
Frequency Response
20 Hz - 50 kHz, +0/-3 dB, 1 watt
Dynamic Headroom
1.3 dB
Total Harmonic Distortion
0.025% at full rated output
0.015% at average listening levels
IM Distortion
0.05 %
Transient IM Distortion
Not measurable
S/N Ratio
114 dB at rated output, IHF A-weighted
106 dB at rated output, unweighted
93 dB at 2.828 V output, IHF A-weighted
84 dB at 2.828 V output, unweighted
Input Impedance
33 k Ω
Input Sensitivity
1 V in for 28.28 V out, THX standard
Inter-Channel Crosstalk
85 dB, 1 kHz
73 dB, 10 kHz
67 dB, 20 kHz
Damping Factor
Over 150 at 20 Hz
Auto Turn On - DC
9 - 12V, 15 mA
Auto Turn On - Audio
1.2 mV - 12 mV, adjustable
15 minute turn off delay
110 - 120 V / 220 -240 V, 50 - 60 Hz
3 watts standby; 550 watts full output
Dimensions
17-1/4" Wide
16" Deep with connectors
4-1/4" High with feet, 3-1/2" panel only
437 x 406 x 107mm, 88.2mm panel only
Net Weight
27 lbs , 12.3 kg
11200 Pesos.
Pre 2100
Frequency Response
THD Distortion
< 0.008% at 20 Hz
S/N Ratio
Crosstalk
> 75 dB at 20 kHz
Input Impedance
30 k Ω
Output Impedance
< 60 Ω
Input Sensitivity
Total Gain: 12 db
General Information
Dimensions
Power Stereo 2125
125 watts x 2, 8 Ω
200 watts x 2, 4 Ω
200 watts x 2, 2 Ω
400 watts, 8 Ω
400 watts, 4 Ω
Current Capacity
Frequency Response
Dynamic Headroom
1.3 dB
IM Distortion
0.05 %
Not measurable
S/N Ratio
Input Impedance
33 k Ω
Input Sensitivity
85 dB, 1 kHz
73 dB, 10 kHz
67 dB, 20 kHz
Damping Factor
Over 150 at 20 Hz
Auto Turn On - DC
9 - 12V, 15 mA
Dimensions
17-1/4" Wide
Net Weight
27 lbs , 12.3 kg
11200 Pesos.
1 mensaje
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 37 invitados
